corner window
hi; new to archiCAD; wondering if anyone would be able to explain how to achieve a corner window in simple easy to follow steps / terms, thanks!
5 Replies 5
Ben Odonnell
Hi there,
Are you wanting to create a corner window or just place one?
What version of ArchiCAD are you using?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Probably both creating and placing a corner window, ArchiCAD v.9; still very new to the program and have final reviews in a week;
so yea putzing around the program and just found the corner window tool. man. much to be discovered about this program.
(corner window tool is in the '> more' area of the tool palette)
Djordje
Quite a bit.
Did you go through the Tutorials?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
yes; well, started; i've been integrating learning the program with studio work and have only made it half way or so; will finish this summer. this program is amazing so far, looking forward to converting some older projects this summer.
