2020-01-0611:45 AM - last edited on 2023-05-2411:31 AM by Rubia Torres
2020-01-0611:45 AM
I would like to customize the 2D symbol of already existing objects in ARCHICAD library. Each object has its own Masterscript, which I do not want to erase (I would also erase the options to customize the whole object) - but otherwise is my 2D Symbol window inactive.
But even if I do so, this changes only floor plan symbol of the object. Where could I change all the elevations of the object?
The image in the 2D symbol window is only used if there is no script in the 2D script.
The elevation views of you object come from the 3D script so you will need to edit that.
There is not a 3D image that you can manipulate - it has to be altered in the script.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
