door 2d representation
Hi
is there a way to modify (reduce) the length of the door opening simplified symbol, wh
thanks
4 Replies 4
Select the Door, go to its Settings Dialog.
In the Marker Settings panel, on its Marker Geometry page, you will see the Marker Position or the Extension Line parameter controls this.
hi laszlonagy
Thanks for your reply. I am using Archicad start edition and I tried to do what you said but cound't figure it out. would it be too much to ask for some screenshots?
I would really appreciate it.
thanks
Luis
Hey again
no need to make the screenshots as I already figured it out. the problem was I had the 2d door opening representation angle to 90 degrees which made the symbol overlap the dimension marker.
Luis
Glad you could sort it out. Way to go.
