β2006-10-20
06:05 PM
β2023-05-24
12:06 PM
Rubia Torres
β2006-10-20 06:14 PM
β2006-10-20 10:36 PM
β2006-10-20 10:44 PM
DrawingStudio wrote:It's not Magic-Cad. You do have to give it a little information to work with once in a while
First of all, you must be kidding (I know you're not)...you can't take a simple wall and insert a simple door? Yikes, wasn't that one of the original beauties of ArchiCAD?
Ok, if you could help me discover the correct place to check this that would be great. I looked under "Wall Selection Settings" and didn't see anything. The door settings seemed so complex that I left them on default.
I'm trying to create a simple stud wall (GWB) with a plain metal door.
β2006-10-20 11:58 PM
β2006-10-21 12:15 AM
DrawingStudio wrote:The wall needs to at least have a couple skins to it, like a stud in the middle and gyp board or some other finish. Other than that, it should work.
The door is set to Stud Wall as you've shown. Do I need to set the wall to the same in order to make it work?
not 'majic cad' now you mean? i think it should work as it did, then you edit the parameters to suit your specific needs. A basic 2hr fire-rated mtl. door and frame should fit any wall type w/ a simple click (for that matter, any door or window should, then you edit it...not edit it first, then place it).I can understand why a window might throw a fit if placed into a 1/2" thick wall.... but you're right, the doors & windows are incredibly intolerant of the slightest unanticipated setting (setting parameters to zero are famous for that)
Why does it need to be classified as stud, cmu, etc. type door? Am I missing a great, as of yet undiscovered attribute of doing it this way?It's mostly for exterior trim work conditions, allowing you to add things like brick mold and deeper trims to span the air space behind the brick. It has a big effect on plan display, since different type of walls can have skins peeled back for trim or the door/window frame.
