2007-12-20 05:29 PM - last edited on 2023-05-26 11:32 AM by Rubia Torres
2007-12-20 06:40 PM
2007-12-20 08:03 PM
Gerald wrote:I just tried it on both the Metal door and Commercial door, and the "Frame Thickness = Wall Thickness" parameter is only available if the "Wall Type" is set to `Solid Wall.`
I just tried it myself and it does not seem possible to change the door frame width on the metal doors. On the wood doors it is possible by changing the setting the 'Wall Type' setting from 'Stud Wall' to 'Solid Wall'.
2007-12-20 09:07 PM
