door tags to show on dim plan, not on finish plan
please help. i have set up our plans set with a dimension plan and finish plan for each floor level. i want the door tags to show up on the dim plan, but not the finish plan. is there a way to assign a seperate layer control from doors and door tags or something else to achieve this? thx
Within the Model View Options (Documents > Set Model View Options) you can turn on or off the display of the markers.
This Model View Option Combination can then be saved with any view.
YES!! THANK YOU
Aussie John
You can also make door refs with ID labels which are layer sensitive.
Cheers John
[/size]
