‎2006-11-29 06:42 PM
‎2006-11-29 07:02 PM
‎2006-11-29 07:04 PM
TomWaltz wrote:i think its a binary (gsm?). how do I save it as a script so i can edit it?
That depends. Did you save it as a script or as a binary?
If it's a script, I usually place the object in my drawing, select it, then click File > GDL Objects > Open Object... which opens the editor. The downside: you have to edit the script.
If it's a binary, sorry, there is no way to edit it.
‎2006-11-29 07:10 PM
slothdog wrote:As far as I know, a binary GSM is pretty much uneditable.
i exported 3d model as dwg from sketchup and then imported into library as an object.
‎2006-11-29 07:14 PM
TomWaltz wrote:slothdog wrote:As far as I know, a binary GSM is pretty much uneditable.
It's been a while since I tried, does the import from DWG give you an option between script and binary?
‎2006-11-29 07:30 PM
‎2006-11-29 07:41 PM
‎2006-11-30 06:10 PM
