Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
error with window script
I am getting repetitive error messages when I elevate my plan.
Message "polygon is degenerated at line 277 of wa_file_us_10.gsm"
I am using AC9 SE library.
Any help to solve would be appreciated.
Thanks
4 Replies 4
Why don't you use the first edition of the library???
Not that has ANYTHING to do with my original question.
Grumpy and wet.
TomWaltz
That error usually means that some parameter is set to 0 that is making the object freak out.
Tom Waltz
From other member posts i know that SE library have this problem with many object, so avoid setting the values to 0 and set them to a very small number near 0 (for example 0.0001)
The first edition doesn't seem to have such problem
