file not found
I'm using a template that I created in V.14 for my students. Ihad to back save it to V.13 so that the students could use it. (my student stations are on V.13.) The favorites tool bar only shows the wall types, the windows and doors are greyed out. When using 3d orbit a warning message pops up "file not found at line____ in the 3d script file" I have tried reloading V.13 libary but no dice.
2 Replies 2
Sounds like the version 14 doors and windows are not backwards compatible with their version 13 counterparts.
There is a migration library when going from 13 to 14 but not sure if it will be of any use going back the other way.
I am not sure of this as I don't use the standard library parts and I have rarely had to save back to 13.
I can see 3 options for you if you can't get the libraries to swap over properly.
In your 13 template delete the offending parts and replace them with ones that work. But this will mean you still have the problem on your 14 machine if you need to save it back again.
So option 2 I would open the file in 14 on your machine but swap the library for the version 13 one. Then fix the problem parts.
Now when you save it back to 13 the library should be fine.
The third option is to upgrade all of your students' amchines to verson 14.
David Maudlin
If the message is actually fill not found, see this thread:
Library Parts Not Working Properly
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
