garden doors
Achille Pavlidis
Is it possible to have a door without the top frame?
I need to place some doors in exterior spaces (gardens etc) that are only 1 meter high, and i dont need the top frame, just the two side frames (see attached sketch) Is it possible?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
8 REPLIES 8
Hi Achille,
Have a look at this one in ArchiRadar. I didn't try, but I think this is what you want.
Erika Epstein
There is a hinged gate in the library under special doors, will that work?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Achille Pavlidis
Thanks for the replies!
@Braza: No it is not what i was looking for. It is an object, not a door, so it is not inserted into the wall etc. Thanks though.
@Erika: Where is that door? Under Special doors, i have Arch Top, Bifold, Garage and Sliding doors but inside them there is no hinged door.(?)
If you not important to use the door tools you can use object shutter style 4. Make the hole in the wall and add shutter.
Gergely Feher
Hinged gate is only available in the US library now.
Regards,
Gergely
_________________
Gergely Fehér
Team Leader, Library Team
GRAPHISOFT SE
One more way for garden gate. You can use Curtain wall for this task.
Erika Epstein
Who knew the US library actually had something the INT version didn't
I was able to email the gates to Achille.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Achille Pavlidis
Yes!
Thanks Erika!
Sigitas, thanks great tips!
Gergely, i think this gate should be available to the INT library also.
