gsm objects
I've got some probably basic questions. How do you:
1. convert 3ds. objects into gsm. files (to use them in Archicad)
2. open 3ds. models in Artlantis just to add them into your project?
3. What to do when dwarfs of downloaded gsm objects (from archibase.com) don't display?
7 Replies 7
1. You need the 3ds import add on. See Help > ArchiCAD Downloads
2. I don't know Artlantis.
3. Dwarfs?
Matthew wrote:
3. Dwarfs?
Bad draw from dictionary?
Best Regards,
Piotr
3. Dwarfs?
i mean thumbnails/icons showing the miniature/ small picture of downloaded object do you know how to solve it?
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Hi esteve,
1. On this site you can find detailed description about 3ds file import/export in ArchiCAD: http://archicadwiki.com/3DStudio
2. As I know you can merge 3ds files to an existing project in Artlantis. Find more: http://www.artlantis.com/
3. Do you miss the preview picture of the downloaded object in Object Settings dialog? Which object did you download? Tip: list of ArchiCAD object download sites: http://archicadwiki.com/LinkCollection/GDLObjectDownloads
Katalin Takacs
David Maudlin
You need to open the object, render a 3D View, then paste this (or any bitmap image) into the Preview Picture window of the object, then save the object.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thank you for quick replies! I will check these sites out
I've read on one of the forums that Graphisoft Shell Extension is incompatible with Vista- probably that's why I cannot see the thumbnails of downloaded gdl objects? Does anyone know the solution for that? Thanks in advance.
