Force Parameter Text
OK, not sure if this is posible but I will give it a go.
I am in the process of creating my own multi-use door for use on future projects.
What I would like to do is force text within a parameter for use in scheduling.
For example, if my door has a vision panel, I would like another parameter to call the code VP
ie
if visionpanel = 1 then
vp_schedule = "VP"
endif
Obviously this script doesn't work. What do I need to do to get this to work.
Do I need to use the Call command?
5 Replies 5
If I am on the right track here you need to firstly have a text parameter called "vp_schedule" in your parameter list.
Then in you master or parameter list you need ...
vp_schedule = "VP"
PARAMETERS vp_schedule = vp_schedule
endif
This will set the parameter value.
Now you can use this as an additional parameter in your schedules.
You should also have something in the code to turn off "VP" when there is no vision panel.
So maybe something like this is better.
vp_schedule = "VP"
else
vp_schedule = ""
endif
Thank you very much Barry,
That is exactly what I want.
For some reason the 'LOCK' command isn't greying out the parameter when I open the object however. No big deal though.
Thanks again, saved me banging my head against the GDL reference guide
In Parameter script type the following (with the quotes) ...
LOCK "vp_schedule"
Gosh, I must of had a brain freeze yesterday.
Thanks
