Tom Krowka
hOLE IN THE WALL
Any way to cut an odd shaped hole in a wall without using a door or window tool?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
draw outline with fill tool and extrude using profiler
seo subtract from wall
bill
Link
Or create a window object out of a slab with an ID of 'wallhole'.
Simply make the slab (the shape of your desired hole) in the floor plan window (imagining the top of the wall is the top of the screen), select it and go to the 3D window, go to File>GDL Objects>Save 3D Model As... then give it a name, choose 'a Window' with 'Editable GDL Script' from the following dialog and the next window you go to insert will be your new funky hole.
Link.
Tom Krowka
Sweeeeeeeeeeeeeeeet!
Thanks
[email protected]
www.walshkrowka.com
