Juju
help me drawing extras
hello,
the drawing extras tool only offers me trussmaker when I added a new library.
 have you a solution for this ?
Steve Jepson
Did you add the Accessories Library?
Also, you might check the content of your Design Extras Menu.  You can edit that to have some additional tools
I assume you are referring to the wall/roof/slab accessories?
Are you using Archicad 26 and did you install the 'Goodies' after you have previously used 26?
If so the goodies will not appear in the menus.
You will need to re-install Archicad 26 and use the 'repair' option (no need to un-install first).
Do not start Archicad yet.
Install the goodies.
Install the latest 26 update.
Now start Archicad and the design extras will be there.
