how do I make door go across two stories with different walls?
Is it possible to make a door and window cross two stories in archicad? When I draw it, it only show half of the door in the 3D - model .
3 Replies 3
Could you post a screenshot here?
If you insist on separate walls for each storey, then you will need to add an empty opening to the second wall.
A door or window can only belong to one wall.
Otherwise use a single wall that spans both storeys.
Thanks! I assumed that, but hoped there would be a button to push..
