how to create an object as "picture.gsm"
mest79
Hi!
I want to create an object as "picture.gsm", with the possibility of inserting a picture.
How can I do?
There is a guide of the GDL script for a similar item?
Thanks a lot!
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
David Maudlin
mest79:
The command to use is PICTURE expression, a, b, mask, you can read about it in the GDL Reference Guide. It is used in the Picture 19 object > 3D Script > Lines 179, 182 and 184.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
mest79
thanks david!
I had read in the GDL Reference Guide but I could not implement it!
and also added a signature
Architect
David Maudlin
mest79:
You can zip the .gsm file and attach it to a post so others can look at the code. Also add an explanation of what you are trying to accomplish and someone will be better equipped to help.
Thanks for adding the signature.
