2008-03-10 08:04 AM
2008-03-10 09:16 AM
mackyboy wrote:close . . .
any suggestion?
!! if these are the parameters you want to hide...
myParameter1 = 1
myParameter2 = 2
myParameter3 = 3
!! ...this is the code
if marker = "Section" then
hideparameter myParameter1, myParameter2, myParameter3
endif
!! you don't need a "showparameter" control because
!! it will always be visible unless you hide it.
!! i.e. if 'marker' is NOT "Section" it will be visible.
!! you may also want to lock them at the same time...
lock myParameter1, myParameter2, myParameter3
endif
!! ...or you can simply lock them without the hiding so that
!! the user knows that they exist. may be an option?
be sure to put this kind of code in the 2008-03-10 08:44 PM
2008-03-11 04:06 AM
