how to make editable GDL Script ?
!ADD2 0.5, 0.4
hotspot2 0,0
hotspot2 a,0
PEN epn
LINE2 -0.5, 0.0, a, 0.0
PEN cpn
LINE2 0.0, 0.0, -0.4, 0.4
LINE2 -0.4, 0.4, 0.4, 0.4
LINE2 0.4, 0.4, 0.0, 0.0
DEFINE STYLE "AC_STYLE_1" "arial",
100*tsize/a_, 7, 0
pen tpn
SET STYLE "AC_STYLE_1"
C=""
C=str(int((y~*100)+.5)/100,3,2)
TEXT2 0.0, 0.377143, "C "+C
this is my script. i want to make it auto editable. my c value generate automatically when i copied an object.
anyone please help me
19 Replies 19
find object.rar
Sorry I can't expand RAR files - only ZIP files.
object.zip
David Maudlin
deval wrote:
object.zip
This is just the 2D Script. Please post the entire object which will have the parameters.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Yes we will need the entire .GSM object file (But Zipped) so we can see where the problem is.
hi, sorry yesterday i could not reply you due to my office hours over. today i am sending you object file which you want. please find an attachment sheet.
thank you
You have only attached an image of you parameter list so we still can't test it.
But it might be enough.
You don't have parameters for "auto_input" which is a boolean parameter and "manual_text" which is a text parameter.
mul2 A/0.009850, B/0.002501
add2 -0.5678904373088, 9.425812062273
pen penAttribute_1
line_property 0
line2 0.5717404373113, -9.42546206234, 0.5717404373113, -9.423662062112
fill fillAttribute_1
poly2_b{5} 9, 2, 0, 3, penAttribute_1, penAttribute_2,
0, 0, 1, 0, 0, 1, 0,
0.5678904374361, -9.425812062273, 1,
0.5717404373113, -9.425812062273, 1,
0.5717404373113, -9.425562062232, 1,
0.5681404371657, -9.425562062232, 1,
0.5681404371657, -9.42356206222, 1,
0.5717404373113, -9.42356206222, 1,
0.5717404373113, -9.42331206218, 1,
0.5678904374361, -9.42331206218, 1,
poly2_b{5} 2, 1, 0, 3, 1, 0,
0.5678904373088, -9.423312062235, 1,
0.5717404373088, -9.423312062235, 1
poly2_b{5} 8, 1, 0, 3, 1, 0,
0.5717404373088, -9.423312062235, 1,
0.5717404373088, -9.423562062235, 1,
0.5681404373088, -9.423562062235, 1,
0.5681404373088, -9.425562062235, 1,
0.5717404373088, -9.425562062235, 1,
0.5717404373088, -9.425812062235, 1,
0.5678904373088, -9.425812062235, 1,
poly2_b{5} 4, 1, 0, 3, 1, 0,
0.5777404373088, -9.423562062235, 1,
0.5777404373088, -9.425562062235, 1,
define style{2} "AC_STYLE_1" "Arial Narrow", 0.015, 0
paragraph "AC_PRG_12" 1, 0, 0, 0, 1
set style "AC_STYLE_1"
"FFL"
endparagraph
textblock "AC_TEXTBLOCK_12" 0, 7, 0, 1, 1, 1,
"AC_PRG_12"
richtext2 0.5684845814529, -9.42578172547, "AC_TEXTBLOCK_12"
this is generate error
I don't see any problems with this bit of script at all.
But it is very hard to say what is happening with out the entire object as the various scripts and parameter list all interact with each other.
The object will be a .GSM object.
It may be embedded in the actual PLN file.
If that is the case then open the Library Manager, select the object in the Embedded Library and Export (save) it to an external file.
Then ZIP that file and attach to a post.
its working. thanks
