‎2019-06-24 08:23 AM
temp4=.5 pen 1 mul2 -1, -1 add2 -a/2, 0 !used for reference line2 0, 0, 0, wall_thickness line2 a, 0, a, wall_thickness line2 a+temp4, 0, a+temp4, wall_thickness wallhole2 5, 2, 10, 10, 0, 0, 0, 0, 0, 0, 0, wall_thickness, 0, a+temp4, wall_thickness, 0, a+temp4, 0, 0, 0, 0, -1 del topwhich, if I have understood the description of the command correctly, should create an opening of width "a+temp4", instead of the usual width of "a". However, the script only draws the three lines I created for reference, and the opening stays the same. Am I missing something? I have attached an image of how it looks now.
Solved! Go to Solution.
‎2019-06-24 10:28 AM
‎2019-06-24 11:26 AM
