kitchen cabinets
Hi all!
I want a tall cuboard but with only one door. After unchecking the upper door I then give the lower door the full height value needed to cover the cabinet, but it will not go the full height. It changes back to a lower value leaving a gap at the top. How do I get this right?
Also, can one change the rotation, height and size of the knobs/ handles for the cupboards? Anyone know of a good site for downloading (free) bathroom fittings GDL's. European style.
thanks again
jonathan
Hello Jonathan
I think you can find what you search in the link included this post http://archicad-talk.graphisoft.com/viewtopic.php?t=2434 .
Good search
bell63 wrote:
Hi all!
Could you not just take a normal kitchen cabinet, switch off the drawer and give it the height that you need?
This drives me nuts, I usually just switch off the standard AC handles and make my own, then position them where they need to go. Which leads onto a question I've been meaning to ask...
How can you add custom handles/knobs to the standard AC ones for use with kitchen cabinets (and doors for that matter)?
no drawers solution...
yes, but then the handle ends up really high above the floor
but if I could solve that problem and also add handles to the library as you ask, it would be brilliant, so if anyone can answer Toms quetion...
yours
jonathan
