libraries in AC13
hi ,
i cant find the libraries & objects in AC13
i am using stuff from AC10-12 but wanna change all to 13
could anyone help ?
i do know they are embedded but cant seem to find them
4 REPLIES 4
please help
Hard to help when your question does not make any sense.
The 13 libraries are inside the ArchiCAD program folder, the same as has always been the case for every version. You have to load them in Library Manager.
Unless you are talking about teamwork, in which case they should be uploaded to your server.
AC 28 USA and earlier   â€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
hi karl,
i know they are supposed to be, but they are not... perhaps the installation went wrong? i did have some problem which i cant recall what exactly.
anyway, is there a way to download them because i vant get through the installation all over again.
It cannot vanish without having been moved or deleted manually. Search your computer for all *.LCF files and see if it isn't there somewhere?
Otherwise, just reinstall - easiest approach as there are dozens of localized libraries and as far as I know, they are not available for individual download, only as part of a full installer package.
Sorry,
