library migration 11 to 18
David Bearss
Still having problems with migrating a collection of apartment buildings. Migrating from 11 right into 18 was problematic and a suggestion was made to integrate an intermediated migration step. Migrating from v11 to v15 shows good results but still some duplicate objects. Migrating from v15 to v18 all v11 objects are dropped and only by installing the v11 library are the restored. Shouldn't these have been converted to v 15 during that migration process?
This is not critical as the projects are workable but will be migrating more projects and would be nice to have a clean solution the works.
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
8 REPLIES 8
Try using the "old migration libraries" - they do not load "automagically"
Either paste the content of "old..." to "Migration Libraries" or load them manually.
Best Regards,
Piotr
David Bearss
Lost me on that one. Have never heard of that. Are they posted and downloadable somewhere?
David Bearss
Alienware 17 R5
It is inside AC folder
Best Regards,
Piotr
David Maudlin
On the Mac they are at Applications > Graphisoft > ArchiCAD 18 > Old ArchiCAD Migration Libraries. There are folders for AC12, AC11 and AC10. Should be similar on Windows.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Bearss
Am again working with some older projects and this migration process continues to fail for me.
I open a v11 project with v15 and migrate and then load old migration library 11 from old migration library directory in Archicad 15 directory. Update and re-load but when opening with v18 all windows, doors and objects are still missing and v11. Obviously missing something.
David Bearss
Alienware 17 R5
David Bearss
So fiddling a bit more. Migrated from 11 to 15 and works fine. Opened with 18 and skipped library migration and all is well. A couple of custom parts missing but not to worry. Why the continual problem with library migration from either v11 or v15 to v18.
David Bearss
Alienware 17 R5
I am no expert on this as I don't use the default Graphisoft libraries.
But if you are migrating from 11 to 15 don't you have to load the migration libraries for 11, 12, 13, 14 and the main 15 library all at the same time?
So the 11 objects migrate to 12 if need be, 12 to 13, etc.
Or are the migration libraries that come with 15 set to migrate directly from 11 to 15?
David Bearss
11 to 15 the libraries do load when I migrate. 11 to 18 or 15 to 18 is the problem.
David Bearss
Alienware 17 R5
