making a library part
its an umbrella column !!
we are making an umbrella column using a beam and with angled columns, but it will NOT make a library part.
I think its some thing to do with the beams used at an angle ?
Ant thoughts from the audience ?
1 REPLY 1
Erika Epstein
Did you mean column with angled beams?
It's the column that is not converting properly, this isn't happening in 12 (only other version I checked). As a work around, save the beam portion only and place on top of the column. If you know any gdl, you could add the vertical column to the 3D script.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
