Can you only use this object for rectangular shapes? I have an L-shaped surface I am trying to model but when I reposition the control points it goes all crazy. I was hoping there is an better way than subtracting out the corner. Thanks!
the problem with the solid element operations is that it leaves the original outline of the mesh on the plan. Is group operations similar to solid ops, just with a group? the mesh is just the 3d mesh from the depository someone pointed me to for doing complex curves and stuff
