migrate custom library to ac29
Guillermo1
hi, wich are steps to migrate custom library created in archicad 26 to archicad 29?
i have linked  the folders of custom object (mep specially) to the library manager but it doesnt appear in the window
If you have created your own custom library in 26, then you can load it in 28/29 just the same as before by loading the library folder in the Library Manager.
However, 28 & 29 do not behave exactly the same as in previous version when loading folder libraries.
If you load a library folder called "My MEP Objects", you will not see that folder name in the Archciad object settings dialogue, you will just see the objects and sub-folders inside that folder.
So you have to create a folder inside a folder if you want to see the folder name in the object settings list.
So you will need your "My MEP Objects" to be inside another folder called "My MEP Objects".
i.e. My MEP Objects > My MEP Objects > sub-folders and objects.
Thank you Barry, solution!
