2024-10-05 11:30 AM - last edited on 2024-10-05 11:46 AM by Barry Kelly
I'm having problems with the tool to convert favorites, is there any tutorial?
Since the link in question is not directed!!!!
2024-10-07 09:16 AM
What does the last few lines in the conversion log.txt show?
2024-10-09 03:07 AM
WOW,where can I download this tool! I have to convert my favorite too!!
THX!
2024-10-09 08:41 AM - edited 2024-10-09 11:07 AM
According to the AC28 New Features FAQ, you have to write [email protected]. They also say that a more user friendly version will be published around the AC28 release. I haven't found anything yet though.
2024-10-09 10:28 AM
Thank you very much Bernd!😁
2024-10-09 01:28 PM
The screenshot @JLopes showed is already about the user friendly version, that can be downloaded from here:
https://graphisoft.com/resources-and-support/downloads?section=favorite-converter
I'll update the link, also the FAQ, and the tutorial video can be expected around 17th October.
Regards,
Magdolna
2024-10-09
01:43 PM
- last edited on
2024-10-12
07:14 AM
by
2024-10-10 02:40 PM
Hi @Funfun Yan ,
Please take a look at the attached manual to see the recommended workflow.
Let us know if it helped.
Best regards,
Magdolna
2024-10-10 04:45 PM - edited 2024-10-10 04:47 PM
Hi Magdolna, Thank you for your manual, it works! And I found the key is we need to use ac 28 to export AND import. The reason I failed was to use ac 27 open the file and export , then used ac 28 to import.
(ps: There will be many favorites that will not trans correctly which will need to rebuild manually.)
Thank you again. Have a good day!😀
2024-10-13 04:50 AM
It doesn't work for the POR (portuguese) version
Regards,
Magdolna
