Favorite Converter Tool - AC28
JLopes
I'm having problems with the tool to convert favorites, is there any tutorial?
Since the link in question is not directed!!!!
|| JLopes ||
AC28 Port |
AC26 Port | Ryzen 9 5900x | RTX3080 | Win
21 REPLIES 21
scottjm
What does the last few lines in the conversion log.txt show?
Funfun Yan
WOW,where can I download this tool! I have to convert my favorite too!!
THX!
According to the AC28 New Features FAQ, you have to write mmarosvari@graphisoft.com. They also say that a more user friendly version will be published around the AC28 release. I haven't found anything yet though.
Thank you very much Bernd!😁
Hi @BerndSchwarzenbacher ,
The screenshot @JLopes showed is already about the user friendly version, that can be downloaded from here:
https://graphisoft.com/resources-and-support/downloads?section=favorite-converter
I'll update the link, also the FAQ, and the tutorial video can be expected around 17th October.
Regards,
Magdolna
Funfun Yan
I converted them, but can't import them in 28.   it shows this.
and the convertion is I think success.
Hi @Funfun Yan ,
Please take a look at the attached manual to see the recommended workflow.
Let us know if it helped.
Best regards,
Magdolna
Hi Magdolna, Thank you for your manual, it works! And I found the key is we need to use ac 28 to export AND import. The reason I failed was to use ac 27 open the file and export , then used ac 28 to import.
(ps: There will be many favorites that will not trans correctly which will need to rebuild manually.)
Thank you again. Have a good day!😀
It doesn't work for the POR (portuguese) version
Regards,
Magdolna
Setup info provided by author
