multi-panel sliding door to each side
Can anyone help with a 6 panel or multi-panel sliding door that slides to each side. I have a multi-panel sliding door object, but it only slides to one side.
Thanks in advance
17 REPLIES 17
aahatimo
dave,
thanks so much for the parts and help!!!
will check them out tuesday. would try them out sooner but its a big weekend in durango. the us pro challenge cycling race is starting here monday morning. big fun, lots of pro teams wandering and riding around the area!
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
aahatimo
dave,
finally trying out your doors, thanks!
one question, is it possible to have a 4 panel slider without it being a pocket door? i have been using your dmx_dx1_pocket, guess it would be similar to your dmx_dx2_slider but all stacking to one side.
thanks again!
tim hanagan
Sightline
Dave. Thanks so much for your help and generosity! Finally, I found a solution for my door
Diego Torres
Architect-CG Artist
Architectural Concepts and Visualizations
ArchiCAD 4.55 - 24
http://www.sightline3d.com
Hi Dave,
Thanks for your awsome library of tons of blocks!
I wanted to see how you handle corner conditions, where you have two different sliders coming together. See attached images for reference image.
Sliding02
Sliding doors can slide both ways; they're very versatile. You have a sliding door that opens to the left, a sliding door that opens to the right, or a sliding door that can be pulled either way.
Lingwisyer
Guru
I just found this in the AC28 library. When did this happen? And you can define how many tracks there are and which panel is on which track!
Ling.
Library 28 update 1 ... https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-28-Library-Update-Available/ba-p/64...
17 years was enough to solve the problem...
The mills of God grind slowly 😁
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
