need help
I am using AC12, and i get this messages.
Anyone have the same problem?
Index value greater than array dimension
at line 262 in the Master script of file PlasterGeometry.gsm.
at line 266 in the Master script of file PlasterGeometry.gsm.
I asked from GS and I was told that this is probably the Turn Plaster part of a Door/Window in a Composite or Complex Wall.
Try to play around with the Turn Plaster settings and also check that your Composite is correctly defined.
thanks, the walls were ok, it seams that the problem was in door. I simply remove the existing door and draw the new one on the same position.
