new personage
Hello
I'd like to insert a SAT PERSONAGE in 3D but I have only stood personages...
How can I do? can I modify one stood personage, or where can I find a new sat personage? does someone have one to send me?...
Thanks very much for your help!
11 REPLIES 11
Hello Sympathetic nerve to see of French here,.
For your personnages you came to see with the three following sites: SudioArkada in Polish and English: http://www.studioarkada.com/
ArchiRadar in Italian and English: http://www.archiradar.com/eng/index.htm
and CAD 3D.it in only accessible Italian after inscription: http://www.cad3d.it/ —look for the object named "Omuncolo 8.pla"
Good luck
;-( It doesn't work!
I can't download any objects and I can't find "Omuncolo 8.pla"! ;-( even if I have registered...
Could you help again giving me a link and checking yourself if it works?
Thank you so much.
Djordje
Ace
Thank you so much.
You have to find the objects for ArchiCAD 6.5 THe posted objects are probably newer, as 6.5 is "only" five years old, and most of the free sites will offer the 7, 8.x or 9 versions.
Student 9 should not be expensive?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
This is the Omuncolo ( is'nt the "omuncolo walking", it's not animable)
for AC 8 +
CU mirco
http://www.3Dsmile.it
1) Select the Omuncolo's position
2) check the box under the image position to HS editing (3D Window)
This is correct links for Studio-Arkada free liblary elements. Unfortunately interface of this objects is only in Polish available. http://www.studio-arkada.com.pl/pliki/elementybiblioteczne/gsm/elementy3d/ludziezwierzaki001_pl.htm
Best Regards
Paweł
The omuncolo' pla (zip) is too big (attachment)
Send me your mail
CU mirco
CUmirco@3dsmile.it
