niche library part
Can someone show me where is the niche library part?. It used to be on the windows library object on 7
3 Replies 3
It would be helpful to know what version of ArchiCAD your are using: responses are likely to be more enlightened if you provide more info.
You can add this sort of info into your profile.
Im sorry , Archicad 9 windows.
But nevermind, I found it.
You can quickly find library parts in AC9 with the new Find Library Parts feature.
Only proviso is the Wall Niche object is a Window, so you will have to search for it in the Window Settings Dialog.
