open a dwg file as a gdl object
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2006-03-17 10:38 AM
ā2006-03-17
10:38 AM
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-03-17 02:12 PM
ā2006-03-17
02:12 PM
mark wrote:
how do you open a dwg file as a gdl object?
Mark:
1. Go to File>GDL Objects>Open Object...
2. In the Open Library Item window, change "Enable:" to DWG File
3. Browse to the dwg file, select, and click on Open
4. The file will open as a GDL library part (this make take some time, depending on the file, similar to opening a dwg file)
5. Then go to File>Save As... to save the library part with a new name into the appropriate library
6. You can now place this part in your project using the Object Tool
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC28 USA ā¢ Mac mini M4 Pro OSX15 | 64 gb ram ā¢ MacBook Pro M3 Pro | 36 gb ram OSX14
