placing doors and windows
in ac10 after merging walls to form a complex profile i can not get doors and windows to appear when i place them in my custom complex profile. has this been encountered before and is there a fix available?
23 Replies 23
My thanks as well Matthew...
I have finally gotten around to changing the trim macro and it seems to have fixed the problem.
Jere
has Graphisoft fixed this problem yet? It's almost embarassing. Finally, we have complex profiles, yet we can't put windows into them?
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Worked like a charm Matthew - Thank you so much!
jbArch
Matthew:
Thank you, thank you, thank you for the work you did on this macro.
Attached are my before and after images of doors that were causing me grief. After updating the macro, all I had to do was select the doors and choose "brick veneer wall" in the general settings. Problem solved.
JB
[/img]
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
