problem with accessible toilet object
In ac17 the ada toilet object places the side grab bar too close to the toilet. ada requires 1'6' center line of toilet to wall (mounting location of side grab abr). in ac17 the distance is 1'4 1/4". Is there someway to change this?
3 Replies 3
David Maudlin
LDieckmann:
On a quick look, it appears that the distance is a function of the toilet's width (which, yes, seems odd). By increasing the width from 1'-2.000" to 1'-5.323" I got the correct 1'-6" dimension. This is a work around.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks. That worked. I also sent an email to tech support recommending a fix at next update, crediting you.
David Maudlin
LDieckmann:
Thanks for adding the signature and reporting the bug. Hopefully it will be included in a Library HotFix.
David
