2008-11-24 11:32 PM - last edited on 2023-05-26 11:29 AM by Rubia Torres
2008-11-25 12:36 AM
2008-11-25 02:37 AM
2008-11-25 04:46 AM
2008-11-25 04:01 PM
2008-11-25 07:05 PM
cremsberg wrote:Hi Claire,
Sure seems like a big, then. What is the best way to get Graphisoft's attention to this bug?
2008-11-25 07:16 PM
2008-11-25 07:46 PM
2008-11-25 08:25 PM
cremsberg wrote:Claire,
There should definitely be a shadow on that wall - no need to change sun angle. Note how shadow properly displays on the door that is in that wall. If I pull wall end away from intersecting outside corner with another side wall (behind the column), then the shadow behaves as desired. See attached. Very buggy!
2008-11-25 08:38 PM
