Learn more
question about window library part ... ?
Is there any "W RIBBON 70" window, or anything similar, with the ability to have transom ... it would really be a big help when making simple, customized windows that require transoms considering that you can have any number of sashes.
- thanks
note : I havent come across any window library part that had the following parameters:
- number of sashes - more than 2 to infinite
- transoms - on/off
a window like this would be quite helpful to me and alot of archicad users out there ... so any help regarding this matter will be greatly appreciated.
3 Replies 3
- thanks
- transoms - on/off
I also found the windows limiting so I wrote my own window several years ago. It does what you want - but it is a commercial product I am afraid, Fastwindow 3 from Objectsonline.com .
thanks haniel. i'll try to check on that. havent really browsed through objects on-line yet. still looking around other sites if they would offer that window. just out of curiosity...is there a cd that anyone could order which contains those "fast windows and fast doors" you were mentioning about. thanks
No, it is only available from Objects Online I am afraid.
