2007-11-09 11:15 AM
2007-11-09 12:05 PM
2007-11-09 12:26 PM
Braza wrote:
Hope it helps.
2007-11-09 04:14 PM
2007-11-10 12:11 AM
Is this how it is suppose to look in this library? Some others tree objects that i downloaded from net look way more realistic!
2007-11-10 11:39 AM
2007-11-10 12:05 PM
The wrote:Now we are talking... In this case you have to open the 3d window in AC and save it as .atl or .3ds (you will need the artlantis plugin or the 3ds plugin). Once you save it open in artlantis and save it as .aof.
Im actually using Artlantis for renders, and ArchiCAD just to export objects as artlantis file. Then open it in Artlantis and save as *.aof object so i can use in it.
2007-11-11 09:26 AM
2007-11-11 01:36 PM
2007-11-11 03:09 PM
Braza wrote:No, i'm not. I know how to export objects from Archi to Artlantis, and make everything work, except with this library. The simplest way to solve this dillema is if somebody tries it:
I guess you are in the wrong forum...
