"Load other Window-Door Marker..."
I am intrigued by the last option in Door Selection Settings > Dimension Marker > ..."Load other Window-Door Marker...". Has anyone written their own window-door marker for this condition, and if so, how was it done?
I'd like to make a door marker that displays only the width.
Thanks,
Mark
12 REPLIES 12
vistasp
Great that you got it working Mark and doing it by hand always gives a better understanding than just looking at someone else's code.
Having said, that, if you'd mentioned what exactly you wanted from the marker, I'd have probably directed you to the "Builder Dimension" marker that came with the SE-9 library. Have a look at the screenshot.
Style-4 is for use with the metric option and can be very misleading if you stick with inches ! 😉
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Hi vistasp,
Thanks for your time and help. Here's a picture of what I wanted and why this solution was perfect for me.
Mark
PS I agree, while we may occasionally want majical solutions, there is no substitute for learning a new skill.
vistasp
snapcrackle wrote:
Hi vistasp,
Hey, no problem Mark. That's a neat marker you have there.
= v i s t a s p =
bT Square Peg
