We value your input!
"boolean" parameter bug? in interactive schedules
I'm creating a custom zone stamp to automate light and vent schedules. In the process I have noticed that when I assign an addtional parameter using a "boolean" parameter type I lose my check mark when I place the schedule.
The check mark displays in the interactive preview but not when placed. Has anyone else experienced this?
Dan K
Aussie John
Hi Dan I dont know the answer to your problem as i cant work out how you added a custom zone parameter to your IS in the first place
Are you able to explain where you did that, it would be much appreciated.
Also did you sort out your problem?
Anyone else is welcome to chime in
cheers
Cheers John
[/size]
cheers
John,
Its been a while since I've done this but I think I remember...so here goes:
Click the "Addtional Parameters" tab and select "All Types by Subtype"
Now under "Select Library Parts", click to: General GDL Object/Drawing Symbol/Zone Stamp/(select the stamp you desire parameters from)
HTH,
Dan K
Aussie John
thanks "select "All Types by Subtype"" was the bit I had missed
Cheers John
[/size]
