2004-05-2409:18 PM - last edited on 2023-05-2412:14 PM by Rubia Torres
render erro
2004-05-2409:18 PM
Sometime when I try to render, it will have window pop out said "erro #64". Then, it will stop rendering. What's erro Type #64? How could I solve the problem so I can keep work on the rendering?
1st, You will need to find out which object/element is causing the problem. Try using the Marquee to isolate areas of the model or select individual elements and view them separately.
