Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
render erro
Sometime when I try to render, it will have window pop out said "erro #64". Then, it will stop rendering. What's erro Type #64? How could I solve the problem so I can keep work on the rendering?
1 Reply 1
David Larrew
Only GS could tell you what the code means...
1st, You will need to find out which object/element is causing the problem. Try using the Marquee to isolate areas of the model or select individual elements and view them separately.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
