scale, stretch in one dimension only
How can i scale or stretch a drawing(a group of lines and circles-not windows or doors ect) in one axis only? is that even possible in archicad?
1 REPLY 1
No.
But you can make an object of it and then scale them. Select the items, and choose File / Libraries and Objects / Save Selection as. Save the object and place it. The object has a length and width, you can divide the value and then you have scaled it. Then Explode you object.
