shipping container model
Does anyone have a model of a 20' ISO shipping container? Or know where to look?
Thank You
8 Replies 8
did you end up finding a shipping container?
i'm looking for one too but can't find it..
if you did. would you mind to share?
thanks
Thank You
vistasp
Mentor
I'm very sure I've seen such an object somewhere - can't remember if it's in the standard library or in AC9 SE. Am away from the main PC now so can't check. Hopefully someone will remember. This won't help you much except to tell you that a shipping container certainly exists as a GDL part!
Cheers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Erika Epstein
there are several in the 20th century library under construction in
ArchiCAD GDL Object Depository at the bottom of the main page of architalk.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks for the tip. but i can't find that 20th century library.. where is it?
Erika Epstein
It's under 02 Sitework 'Construction Equipment Library '
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
got it. thanks!!
Good day.
THat is three wall editable 20ft shipping container:
https://skfb.ly/6DwQR
Aaron Bourgoin
The BIM Bakery in South Africa sells a highly parametric Shipping Container Object.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
