Llian
slider door leaf
Sometimes I do see the door leaf thickness but I am not sure why sometimes, it shows just a line. How do I get it back with leaf thickness?
The floor plan display is symbolic.
ps: I try attaching a 12kb jpg screenshot and it is not showing up.
Thanks.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Llian
Found the answer…uncheck MVO
Remember the MVO combinations are saved with your view settings.
So make sure you update your MVO combinations (i.e. 'store as') so your views have the correct settings.
Otherwise you may find it will just switch off again when you change views.
