‎2015-01-2701:08 AM - last edited on ‎2023-05-2411:42 AM by Rubia Torres
‎2015-01-2701:08 AM
Is there a way to have the lower rail on a storefront door that has a sidelight be different than the lower rail of the sidelight? I want a 10" rail on the door and 2" on the sidelight. The only way I've seen around it is to have a storefront door with out a sidelight with a storefront window adjacent to it. Any help would be appreciated.
the object seems to use the same parameters for door and sidelight frame dimensions. I'm afraid you have to stick with door and window side by side.
