the AU Windows in the Australian essentials library 17
Just trying to set up our new version of 17 and im trying to get these windows to work and having a few issues.
anyone else use these window and able to help out?
Cheers
Gene
1- in all these windows i can not find an option to show which way the windows open (arrows/opening lines) in the elevations/3D views.
2- unsure how to change the arrangement of the openings. EG i have a 2 panel casement but it only shows one as an opening leaf in plan, i have a 2 panel awning but it only shows one as an opening leaf in plan, etc.. how can i make it show both as openable? can i show the swing of a casement in plan.
3- the casement in plan looks the same as an awning? can i show it as a swing line so people can tell the difference when viewing the plans.
Are the swing lines controlled in the Model View Options?
As for the one or two opening panels that should be a parameter in the object.
If it is not there then there may be another object you need to use.
I'm not entirely sure as I don't use these objects so haven't looked at them yet.
But this is the way it usually works.
yeah modle view was ok.
just some settings i missed in the window setting.
