the inclined lines in objects and morphs elevation's view?
Dears is there any way to hide this inclined lines in the elevation and section view for in documentation?
photo attached
If it is an object there is not a lot you can do - that is how the object is scripted.
Except convert it to a morph.
Once it is a morph you can select sub elements (CTRL+SHIFT) or switch to the sub-element selection cursor, select the morph lines and change them from a 'hard' edge to 'hidden' in the morph settings (or info box).
