update the old library parts
Hello
I look forward to update custom library from the V9, its size
Currently I use V17, and update a part of the library, it is claimed to be me additional information, including the selection of a license for the type of object
I think this is just a form and, if I am using the full object for myself, Que pull Add in this pane, and choose the type of license a little irrelevant
Only when / if I decide to share this information shared library that is significant (I assume modify shared library automatically uploaded arent anywhere)?
Is there a KB article, or some other available information, a list of all
Thanks for any helps
yukioMishima
4 Replies 4
vistasp
Mentor
Yes, it is irrelevant if you're using the object yourself.
The license field was introduced along with the BIMcomponents website where users can share their gdl objects with the community.
Maybe GS should make it a compulsory field only if someone is uploading the object.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
thank you
Therefore, unless uploaded independent of any information in the DETAILS tab? (informations in details tab irrelevant)
Is automatically uploaded object, or you need to use BIMcomponents account and formally submitted?
vistasp
Mentor
You need to have a BIMcomponents ID to share objects.
Objects will not be uploaded automatically.
= v i s t a s p =
bT Square Peg
thank you
