Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
DGSketcher
Legend
v19 DateTime function returning (null)
I'm working on a GDL object that would benefit from date tagging but I can't get the date using any of the normal Request syntax methods, even the following example in the GDL manual returns (null)...
dstr = ""
ch = OPEN ("DateTime", "", "%w/%m/%d/%Y, %H:%M%P")
n = INPUT (ch, "", "", dstr)
CLOSE (ch)
PRINT dstr !it prints 3/03/27/1996, 14:36 PM
PRINT GLOB_PROJECT_DATE also returns a set of zero's.
The routines have all been placed in the Master script.
Anyone else aware of this? I would have thought it was fairly critical as a routine. Has something changed recently and I've missed the memo?
I am running v19 on MAC 10.10.4
2 Replies 2
Gergely Feher
this request works on my system. I tried it in both 3d and 2d (with text2), and both of them works. Please take care, that print command normally writes to your report window, it does not start a new window like a warning or error.
The global variable of the project date is only works with the energy evaulation, it only gets value by this addon's functions. In normal 2d or 3d it has no value.
Regards,
_________________
Gergely FehΓ©r
Team Leader, Library Team
GRAPHISOFT SE
DGSketcher
Legend
Thanks for the response Gergely. Everything seems to be working in the final code, but I was getting the unexpected responses in the programming domain. It is a while since I flagged this up so my memory has forgotten what I was doing to get the null response. No problem, job signed off
