volume3d() function
alemanda
does anybody have some experience with the function VOLUME3d().
In order to have the volume of a 3d shape, where do I have to insert this function?
Thanks
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
4 REPLIES 4
Jochen Suehlo
!3D-Script
BLOCK 1,4,9
!Properties Script
menge=VOLUME3D()
DESCRIPTOR STR(menge,3,1)
!(or COMPONENT .....)
Find in a component list (not interactive) the result: 36
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
alemanda
Thanks! now it's clearer.
AC27 latest hotfix
Win 10 Pro 64bit
is there a chance to make it two ways for data?
something like it has a block with known volume.
i would like to know if there is a way to know where it will be this output and if can be linked to the object and not to the project.
